Kamakazie! said:size?
can you go sata 2?
anything from samsung, hitachi. seagate, wd or maxtor in your budget will suit...
samsungs are usually the quietest.
hitachi the fastest.
seagate the longest (5yr) warrenty.
i think thats about right.
Gabriel said:Unfortunatly only SATA not SATA II
Can I use a SATA-II On A SATA Motherboard ?
Rambaud said:That should not be a problem, as SATA II is supposed to be backwards compatible.
No problem with mine on a SATA I mobo.
Meetgrinder said:Just don't touch Maxtor and you will be ok.
dual2max said:Buying a Maxtor is like shagging a minger, yeah its got all the sockets but you regret it the day after.
Meetgrinder said:Back on the Maxtors - I never had bother before their Diamondmax series. Still got old ones from 10+years ago that chug along nicely.
