Recommend me a PC
18 Jun 2023
london
Hello
I haven’t built a computer for 12 years! That one just died but was pretty good until the end.
Would one of you be kind enough to recommend parts for the new build?
I want a very snappy reliable pc with plenty of space for programming and some gaming - don’t want to spend more than £350 on a gpu and want it to be v quick for general computing. I already have an ultra wide monitor (41” ASUS something).
Thanks a lot
Ben
Not right at the moment
Well ii not then here's a AMD alternative
3060ti v 6700xt review.
Awesome thanks so much !
Couple of potential tweaks. I don’t need WiFi on the motherboard and would prefer a 2tb drive. Any thoughts on those? Otherwise looks great
Looks like 2TB drives are 3x the price, maybe a 1TB for now and I’ll add another later on when I need it. Is there any harm in installing an old spinning disk drive for storage of old files that don’t need quick access?
2tb drive is £105
Alternative cheaper motherboard without WiFi but think the Asus is worth it.
Perfect thanks. Couple more questions if that’s ok and I really appreciate your time
1. Pc part picker has not heard of the PSU you suggest but has heard of this https://www.overclockers.co.uk/msi-...source=************ _127079_Communities+&+UGC - what’s the difference any idea?
2. The motherboard has Bluetooth - finally Bluetooth on a desktop! (For me) - this is gonna work right I can use bluetooth headphones etc.
Aren't 41" Ultrawide monitors usually 4K (or higher)? :o
If I'm right and you want to game at that kind of resolution, £350 is not going to work. Realistically, you'd need to blow your entire budget just on the graphics card. At the very least, I'd want a 4070 or 6800 non-XT for 4K.
If you only mean casual gaming (especially older, or esports games), then sure, you might get away with it.
1. Pc part picker has not heard of the PSU you suggest but has heard of this https://www.overclockers.co.uk/msi-mpg-a750gf-uk-psu-750w-80-plus-gold-certified-fully-modular-ca-00h-ms.html?awc=28821_1687111806_46627f0b69ea71a886d968e9d8455e61&utm_medium=affiliate&utm_source=************ _127079_Communities+&+UGC - what’s the difference any idea?
Well it shows just how good Overclockers are at bringing the latest tech to it's customers.
Bluetooth as well as WiFi, win win .
I just won’t run it at native resolution then. The budget is just what it’s worth to me.
Sure it will; you're just going to be running on medium settings or upscaling or both.
