- 26 Apr 2004
- Milton Keynes
Bar the way I've worded it, the title is actually serious.
Im looking for a new mouse; its got to be wireless as I'd like the option to use it with my new Plasma monitor/tv, and have at least one preferably 2 thumb buttons (I'm using a Logitech MX518 at the moment, and I find I do use the side buttons quite a lot!)
Ideally I dont want to spend a huge amount; but as its going to be used for gaming, as low a response time as possible, and possibly an internal, replaceable chargeable battery would be good.
I have a cheap logitech wireless that came with a keyboard set, which is OK, but occasionally just drops out and isnt as sensitive as I'd like (I'm used to 800dpi equiv mice)...
Suggest away!
Suggest away!
