yeah so fifa for example a game which people who play it will regularly play it for a few hours straight every night. has static images all over it. the logos, team names, radar in corner, etc.
same goes for if you have a specific channel you like to watch. let's say you watch a lot of sky sports. the logo will soon become burned in.
varied content is all good and well. but people do tend to have a lot of static content too. plus burn in is only 1 of the issues OLED has you guys are forgetting screen uniformity, etc.
i'll quote my own post "as long as you are aware of the pro's and cons of each tech and oled suits your usage you will be fine.
i ended up buying another screen because of image retention. purely to game on. to save my plasma from it. it's why when i moved house i stuck the plasma in the bedroom and went lcd in both the living rooma and games room."
so just because it suits your usage doesn't mean it suits everybody elses. don't be so quick to call BS when you don't know the full facts. just because you are happy with OLED doesn't mean everyone else will be. which is why i specifically stated so long as you are aware of all the pro's and cons and it suits your usage.
So basically if you watch the same TV channel for 20 hours a day, for a few weeks then you might need to replace your TV, or your eyes which ever fails first?
no you never read it right
"Our previous
20 hours per day burn-in test is still running and the OLED TV already has permanent retention. That test is an extreme case, using patterns with a lot of static content.
Based on your feedback and comments, we have bought 6 LG OLED C7 which will play real, non-altered content. This should give you a better idea on what to expect depending on what you watch on your TV."
so they have done a second test using varied content
Uniformity issues continue to develop on the two TVs displaying live CNN, and this is slightly visible in normal content when looking for it.
The goal of the test is to provide an idea of the usage time of a 2017 OLED TV before burn-in becomes apparent, which will depend on your usage. To do so, we will replicate five different real-world conditions in an accelerated aging test. We will also independently test two different brightness ('OLED Light') settings with the same content to see the impact of this.
Do you guys know if OLED uniformity issues get worse over time? I purchased a B7 and have noticed a warm, vertical band on the right side of my screen. It is only noticeable on grayish colors, some solid colors, and some panning shots. It is quite benign, but I’m worried it will get worse and become prevalent in all conditions.
It shouldn't get worse. This kind of non-uniform color across the screen is unfortunately common for OLEDs
With OLED TVs, the gray uniformity issues are more related to imperfections in the panel itself, independent of pressure-related problems.
- OLED TVs tend to do quite well with our test, which uses a 50% white (medium gray) image, but they have much worse uniformity with darker colors, which can be an issue. This is why we have added a 5% white (dark gray) image in our gray uniformity test.
Unfortunately, there are no steps that can be taken to improve gray uniformity – it’s entirely down to the panel you get. If you find yourself with uniformity that you cannot live with, you should exchange your TV for a different unit, or even a different model.
