- 12 Dec 2002
Hi, I'm after a new set of 225/40/18 tires for my Astra Vxr and I'm looking for some opinions. I currently have a set of Yoko Parada spec 2s on my car which I had purchased after the original conti sport 2s had worn out, I wasn't expecting much when I brought them (a relatively cheap set of rubber brought as it was the beat tire stocked) but they were absolutely sensational in the dry although rather poor in the wet.
There dry performance was most likely due to the soft compound used as these tires are now dead after 7k miles.
Could someone recommend a good tire to rival the dry grip of the Yoko spec 2s with perhaps more wet grip, I plan on a few track days so a performance tire is preferable.
Any opinions on conti sport 3s? Or Pilot sport 2s?
