Recommend USB Stick
Permabanned
2 Feb 2010
Haywards Heath
Can anybody recommend a USB stick 3.0 at 512GB ? around £100
Is it worth buying USB C and its that a faster way to transfer data ? as i have USB C on my Lenovo Legion
:D Thank you :D
For that budget you can get a portable ssd. But if it needs to be in a thumb drive form factor then Sandisk Extreme PRO, it's solid state too so very quick.
As above an NVMe drive isn’t that much bigger, but for letting ditties the Samsung Bar Plus isn’t bad and neither is the Sandisk EP above, if you want small, Lexie Jump S47 was decent enough, but nothing compares to a proper NVMe drive in a pocket size caddy.
