Unless you have the cash to burn, I wouldn't get a pair that only works with the AMP (i.e. the RS series from Sennheiser).
I'd still go with a Bluetooth pair, as you then have the option to take them with you should you choose to.
I would suggest a pair like Sony's MDR-1000X or Bose's QC35, both of which can be found around your budget if you look hard enough.
Edit: I've owned the B&W P5, and while they sound fantastic, I found the pressure they exerted on my ears after prolonged use was a little too much, and caused a fair bit of pain. Same with the P7 - the clamping force was a little too high.
Edit: I've just noticed your AMP doesn't support Bluetooth. Some TVs do however. Also, you already seem to have purchased a pair.
I'd definitely appreciate a post about your thoughts on them
