- 18 Oct 2002
- Cambs
R5 Turbo
Engine Size 1397cc
Valves 8
Cylinders 4
0-60 mph 7.3 seconds
BHP 115/120
Max Speed 122 mph
Astra 16v GTE
Type: XE
Capacity: 1998cc 16v
Compression Ratio: 10.5:1
Cylinders: Four, in-line
Cylinder Head: Alloy
Block: Steel
Installation: front mounted, transverse
Valve Gear: double overhead camshafts, overhead valves, four valves per cylinder, toothed belt drive
Induction: Bosch Motronic M2.5 multi-point fuel injection, mapped electronic direct ignition system
Max power: 150 bhp @ 5600 rpm
Max speed: 137 mph
0-60 mph: 7.4 seconds
Max torque: 144.6 lb.ft @ 4800 rpm
I'd still go for the Toyota GTI though as I've sat in both the GTE and the R5 and they can be very old fashioned and rotten lumps for the £500 mark. Couldn't find full specs for the Toyota though but i'm relaibly told 0-60 is just under 8s and I can confirm the engine is the same as the Mr2 mk1 whiich features variable induction(kinda acts like a mini turbo)
Engine Size 1397cc
Valves 8
Cylinders 4
BHP 115/120
Max Speed 122 mph
Astra 16v GTE
Type: XE
Block: Steel
Max speed: 137 mph
