Man of Honour
- 17 Feb 2003
- Chelmsford
I'm looking for a 24 - 70mm lens for my 70d
The Canon f/2.8 version is just too expensive but the Sigma version looks ok..
Sigma - http://www.cameraworld.co.uk/new-eq...sigma-24-70mm-f2-8-ex-dg-if-hsm.html?___SID=U
Tamron - http://www.cameraworld.co.uk/new-eq...m/tamron-24-70mm-f2-8-di-vc-usd.html?___SID=U
I was wondering if anyone has this lens and would recommend it over the Cannon or Tamron versions?
I assumed that the OP understood the effect of the crop factor from the fact that he asked whether a 24-70 lens would be equiv. to 38-112. I'm sure he was capable of working out that a 17-55 lens would also be subject to that crop factor. You're complicating things for no reason. It wouldn't even make sense for me to suggest a 17-55 lens if I had meant equiv. focal length since such a lens (10-35) doesn't exist (Tokina do an 11-28 I think but not F2.8). No part of my post suggests that the crop only applies to EF lenses.
