When I mean cloud I mean the actual cloud controller, I don't mean the free controller you can run off your own dedicated hardware/cloud key (which is still local hardware). Notice in the original comment I used the word "cloud". I did not mean the controller software itself which I'm aware is free to use. I was originally comparing to ZyXEL's cloud management too. Apologies if my wording wasn't clear enough.
@Matrix in that case just a single AP will do. The Unifi doesn't have a web UI to access on PC so you'll have to depend on the app on the phone.
So i assume either the yXEL or the UniFi 6 Lite Access Point will do the job then fine ? Is any of them any easier to set up or both the same ?
Thanks
