recommendations for purchasing an external HDD enclosure
6 Oct 2012
(do-or-die) Wye, Ashford, Kent, UK.
evenin,
i'm going through the process of diagnosing a boot loop issue with my pc, but ultimately i just need to get the HDD out and plug it into the back of my mac to transfer files.
it is SATA
3.5inch
i've checked amazon/ebay and pc world
amazon and ebay generally come up with 'Startech'
pc world generally sell 'Dynamode'
is there any real need to shell out £50 instead of £15-£20?
i would appreciate any recommendations etc :)
baz
icy box are good. the only benefits of the more expensive ones are more connectivity options, and better/different build qualities.
icy box, you say? right, i'll look around for them, although i need one for 3.5".
you mentioned "more connectivity options"? what might these be?
Have you considered a docking station? May not be suitable for your needs but I have one of these and it's excellent!
http://www.overclockers.co.uk/showproduct.php?prodid=HS-060-AK
i have considered them, and i would get one if they were around the same price, which, upon looking, they seem to be.
they seem to do more-or-less the same thing, while the only difference is that docking stations are more accessible, and designed for people that need to access various HD's frequently.
i'll look for docking stations, if i find one for around £20 or under, then i'll probably do that.
Cut the cost a bit by sticking to USB2 rather than 3. For most tasks I need an enclosure for, the extra speed is just not particularly needed.
I just bought an Allcam one, works fine plus no screws so is easy to swap disks out, was around £17. Works with eSata too, which is nice.
more connectivity = it might have usb and esata or fireware etc. cheaper ones tend ot only have one option, in which case USB has most flexibility, esata has more speed. Unless ofc you're going USB 3 in which case its probably just simpler to go for that.
But, if you are just backing up stuff, and not regularly transferring more than say, 20GB, USB 2 is fine.
