- 4 Oct 2019
- Queens Park - London
Shouldn’t be too dissimilar to the 7800X3D but wait for reviews before you do anything.Hi all
To save opening a whole new thread, I'm going from a 8700k to 9800X3D soon, I plan on 2x 32 memory. Not planning on any manual overclocking, just plug and play (delid of 8700k was hopefully my last migraine), looking for balance and stability for the memory, budget is not a factor.
Is all the info in this thread relevant for the 9800X3D, ie 6000Mhz CL30. Or is there some unknown until the CPU is released?
Cheers
If you want, you could consider 6400 MT/s RAM and see if that works or just run the 6000 MT/s speed profile if it doesn’t.
What motherboard are you considering? A good quality AMD board would support 6400 MT/s or even 6600 MT/s speed RAM.
Considering I want plug and play, it will prob be the 6000 CL30 kit.
