Hi guys,
I'm after a decent PHP coded, web based inventory/asset system for work. It needs to have a small app that runs on the individual PC that will send updated data every so often to the server running the server-side software. It doesn't need to have ticketing etc built in, and is really just to allow us to keep track of serial numbers/software being installed/IP addresses/domains etc.
We have about 350 sites on ADSL VPN connections into our central local network which our server sits on, so ideally any uploading of data from the client PC's would be done over port 80 so we don't have to mess with opening ports on routers owned by BT.
Basically i have no idea where to start looking so i'm after some recommendations, so far i've seen these two:
They do the sort of thing im after, but i've never used anything like this before so was hoping for some opinions or advice on what to go for...
Thanks
Thanks
