Recommended power supply for 980 ?
Hi and welcome.
Your link doesn't work but I am guessing it is a Gigabyte G1 card?
Can you list everything in your system? and if you wanted the option of SLI (if its supported by your board).
Hi and welcome.
Yeah its a 980 sorry about the link. My system will be as follows
- Case: NZXT h440
- CPU: i7 4790k
- Motherboard: Gigabyte Z97X-Gaming 5
- RAM: CORSAIR VENGEANCE 1600mhz i think
- Graphics:Gigabyte NVIDIA GTX 980 4GB DDR5 PCI
- Primary Drive: WD 1TB 3.5 inch Internal Hard Drive - Caviar Blue
- Power Supply: xfx 550w currently need to replace
Thanks so much for the help in advance :)
sorry about the previous post missclicked :(
Yeah it will work on that PSU and XFX PSUs are usually made by Seasonic so its not a nasty item.
I would have only suggested this PSU anyway - https://www.overclockers.co.uk/showproduct.php?prodid=CA-024-EA - Fully modular, Gold rated, made by Seasonic, Eco fan mode so turns off at low load/temperatures.
SLI would be a 850W PSU and this one - https://www.overclockers.co.uk/showproduct.php?prodid=CA-017-EA - is in budget and made by Superflower.
Thanks for the help i appreciate it :). Is there any 750w power supplys you recommend too.
