Recommended power supply size
9 Nov 2010
After everything everyone just said about power supply sizes,
I just did a test, on Asus, Cooler Master and 1 other, cant think of name, 2 said average Wattage is 900, 1 said Your Recommended Minimum Power Supply is 950 Watts. So now what power supply would you recommend to me :rolleyes:
i7 2600k, months ago did run at high ends of 4ghz, until i blew my PSU,
ATI HD Sapphire 6870's crossfired and slightly overclocked.
4 Fans,
Water cooling,
1 HDD
1 SSD
1 Optical Drive
16 Gig Ram
But these power supply calculators suggest 900/950w lowest??? You really think ill get away with a 650/750, with a crossfire 6870 using around 300w for the crossfire, and an i7 2600k @ 5ghz area :/ ?
They are just over compensating.
Trust me when these guys say a 750w is enough then it's enough, i know quite a bit about PSU's and OEM's yet i still come here myself for advice on power supplies.
Ok, just to spice things up between everyone ;) lets say i want the best power supply, being the wattage, or what other things come to mind, your the experts, you tell me :)
So the best power supply, for £120.00, give or take.
Be carefull when overclocking bud, especially if you are looking to hit 5ghz as this requires a fair amount of voltage (think this could be part of the reason for your problems) I would follow strict guides in this as you could easily blow your chip/mobo (I did on an old pentium 4 proc).
So as my last thread got closed :p
how do i check for errors on my SSD/HDD???
And after that, if they are clear, how to tell if my Processor is faulty??
If your computer still will not boot after a Clear cmos/load fail safe defaults then you will need to try them in another computer. You will need to get the manafactures HDD tools and the same with the SSD. As for the processor, if that was faulty I am pretty sure it wouldn't even let you get to the bios screen.
