- 22 Oct 2012
- The Moon
Hi,
In the future, I was considering installing a 280mm radiator in the front using the Evolv ATX. This requires removing the hard disk tray which is currently populated by one 3TB WD Caviar Black. What enclosure would you recommend as a solution?
Cheers.
Cheers.
