Hopefully someone can help after my fruitless google search.
I have a 2TB Samsung SATA hard drive in an external enclosure that has obviously developed some bad sectors after being dropped at one point in time in the past.
The issue is that I was trying to access a file on the hard drive and it hanged, so I obviously assumed it had some bad sectors corrupting that file.
The problem was that I ran windows disk check on the drive, and it just appeared to hang after a certain point. Thinking that the software had crashed on the bad sector, I cancelled the scan.
Since then, windows has not be able to read the drive. It can see that the Samsung drive is connected, and it thinks it's all ok, but in explore instead of showing up as E drive, it's G with no name and inaccessible.
The thing is, my data is still clearly on there and mostly ok, because when I connect my HDD to a TV, it sees the files and I can play them (I haven't tried every single file, or the one that caused the whole crash).
My other concern is that when I have the HDD connected to windows, I can hear just constantly clicking, a sure fire evidence of the HDD's imminent complete failure, so I want to replace it, but get all the data off first.
Any thoughts on how to get windows to see the hdd properly again so I can save my data?
