Recycling Oil touched equipment
10 May 2007
Hi peeps,
I will be taking my old oil to a oil recycling place tommorow
Just 1 question tho, what do I do with funnels etc that have touched the oils? Best to rinse them of (let that drain into the oil then dispose) or should the low amount of oils on these be ok to simply chuck in the bin without causing issues.
Cheers
18 Oct 2002
Birmingham
don't use them in the kitchen afterwards, but i clean mine with acetone/meths/white spirit or whatever solvent i have in abundance and use them again for car related stuff
18 Oct 2002
Devon
Exactly...why would you throw them away? :confused: You don't even need any solvents, just give them a wipe over with a bit of rag or kitchen roll and put them away for next time.
18 Oct 2002
Wipe with rag. Done. You get a pretty coloured flame if you burn the rag too, that wouldn't fit in with the hippy thing though, I wouldn't imagine.
24 Apr 2007
Southport
There are places to recycle oil these days? ;)
I assumed everyone just took the sump plug off and got out of the way of steaming hot oil pouring everywhere!
The Exxon Valdez tanker lost millions of oil to the sea, another 4 litres from my car aint gunna do any harm :p
3 Jul 2008
Fife way up in Scotland
Reminds me i have about 4 litres o the stuff to get wrid of.
Last load was in a milk carton. One of the big plastic ones. Couldnt be botherd ghoing to the dump so left it in the garage came in one day to find the carton had melted and was pouring oil everywhere. Wont do that again.
Must have affected the plastic some how.
Man of Honour
11 Mar 2004
wipe and save for next time, as for the oil it is the best weed killer known to man. Got a wall you always have weeds growing up the side of. Pour a thin line of the oil along the bottom. Or take it to the dump. absolutely no point throwing out funnels and stuff though. And if you really want to clean them use something like paraffin.
Jez
Jez
Caporegime
18 Oct 2002
I'm no tree hugger as you probably know but i really hope that you dont really do that :eek:
