My guess... without consulting your MB manual... is that the top 2 red ones are eSATA ports![]()
I believe I read somewhere that for my board (P8P67 PRO) the red ports are powered (for charging smartphones/iPods etc), though I can't recall where I read that.
ASRock said:ASRock App Charger
Fast Charge & Charge Anytime
Simply installing the App Charger driver, it makes your iPhone charge up to 40% faster than before. ASRock App Charger supports continuous charging when your PC enters Standby mode (S1), Suspend to RAM (S3), hibernation mode (S4) or power off (S5). The App Charger technology has been fully applied on ASRock Full series motherboards.
There is only 1 eSata on the rear, thats the one at the bottom.
Those ports are red for one simple reason, its one flow of plastic in the mould. It was probably just easier to leave them red. According to the specs they are just a bog standard usb2 port.
and it was at a end of a long shift.
