I upgraded from an i3-2120 to my new i7-4770k yesterday, now trying out overclocking (first time).
Case: Corsair 540
Board: Z87X-OC
CPU: i7-4770k
Cooler: Corsair H100i
I'm using RealBench v1.1 to test stability and have 4.5 stable right now but the temps seem a bit too high.
Multi: 45
Vcore: 1.295
Ring: : 1.114
Vrin override: 1.75
Vrin LLC: Extreme
C1E, C3, C6/7, EIST: Disabled
No other settings changed. I would like to OC my memory and gpu once I have the CPU stable at reasonable temps.
Just opened Corsair Link to try setting the fans a bit faster and found it isn't reading the h100i temp/fan speeds (it was before I started trying to OC).
I'm going back to stock to check if that fixes Corsair Link then going to try get those temps lower, any tips to reduce them?
			Case: Corsair 540
Board: Z87X-OC
CPU: i7-4770k
	Multi: 45
Vcore: 1.295
Ring: : 1.114
Vrin override: 1.75
Vrin LLC: Extreme
	 (Although memtest reported no errors after 2 hours).
