- 29 Aug 2010
- Cornwall
Hi,
So I'm using a reference 290X (Powercolor). We all know the cooler is loud, very loud.
You all know that and I knew it before I bought it, it wasn't a surprise.
I originally planned to watercool, but for me watercooling is something that always seems like a good idea right up until I actually have to strip everything down and fit it.
So, now I'm using the 290X with reference cooler.
Has anyone with a reference card changed the TIM but continued using the reference cooler?
If so, does it make much difference?
I know a while ago a few people replaced the TIM on MSI Gaming versions of the card (or 390s or something close) and it made quite a difference.
Does the same apply to the reference card? Or is the TIM not too bad on those, or the reference cooler isn't good enough for it to have much impact either way?
I'm hoping that if it can run a bit cooler it can run a bit quieter.
