- 29 Aug 2010
- Cornwall
You can with software if your mobo supports it which i think it should as long as your using PWM fans. Have a look at speedfan, you can control individual fan speeds based on temps i believe and also corsair link does the same too. I have a fan controller in my case so i just have all my fans running at a certain speed where it's just audible but fast enough to keep my temps down which IMO is easier than messing with software running in the background.
Yeah, I'll probably do that too.
I was hoping you could attach it to the normal GPU fan header, but forgot you'd need to plug in the old fan.
