I'm thinking of upgrading my graphics card, as my 6850 doesn't really cut it any more. To this end I have my eye on a reference nvidia 670 as a replacement. However I am concerned about the amount and quality of noise it might produce, especially when idle.
The most audible thing in my PC at idle is the rear exhaust 120mm fan at 800rpm and I am wondering whether the reference 670 might overwhelm this in an annoying manner? The Tech Report's views aren't too appealing:
Ta
I was wondering whether any of you guys have any alternative views?Yeah, well the GTX 670's cooler sounds cheap. That's why the 670 is relatively noisy at idle, even though it has very little power—and thus heat—to dissipate. The GTX 670's blower emits a rough, friction-filled whine. It's not especially loud, and heck, the thing manages not to register too high on decibel meter under load. Tucked inside of a case that insulates sound well, you might barely notice it. Still, this thing isn't Nvidia's best work.
Ta
