Refresh rate randomly changing
2 May 2017
Hi all,
Ever since I got my new PC with a 2080Ti, I’ve noticed at times the refresh rate will randomly change. For example, whilst hooked up to my 144 hz monitor with g sync enabled, it’ll be smooth for most of the time. However, in certain applications, it’ll be as if it suddenly shifts to 24 hz.
Some software when this happens is when using Handbrake, CCleaner and, bizarrely, when saving a game in Crusader Kings 3.
I’ve also noticed some unstable refresh rates when connecting up to my LG OLED.
I’ve re installed the drivers and even re installled windows but have encountered the same thing.
It’s not really an issue, but more a curiousity and wondered if anyone had any ideas? G sync is enabled for full screen and for windowed.
That's probably a G-Sync issue, because it sounds like what bothered me for years before I figured it out. If you set up a profile in the Nvidia control panel for the specific application(s) causing that behaviour and set it to use a fixed refresh (there's an option there somewhere), it'll stop happening. Windows Firewall Control is another program that causes it to happen.
Movies and some in-game cut scenes playback at 24 / 23.976 fps
Sounds like some kind of v-sync / adaptive sync issue where it's trying to match the framerate of the source or application.
I'd have play around in the NVIDIA control panel, make sure things like v-sync is not being controlled by the application etc.
How did windows firewall cause issues with gsync? And what did you do to fix it for the firewall?
Thank you very much. That's sorted it. This never happened with my 1080 so wondering what caused it now. Thank you very mcuh for your help.
