Hey guys,
I recently purchased an OCZ Agility 3 SSD (http://www.overclockers.co.uk/showproduct.php?prodid=HD-076-OC&groupid=701&catid=2104&subcat=1427), and I was wondering if my write/read speeds are correct;
Note: I have it connected to SATA2, which might explain the ~266mb write/read?
The SATA3 on my motherboard is controlled by a Marvell 9128 controller - I have read many bad things about Marvell, and some suggested that using an Intel SATA2 would have a better performance.
Any advice/help would be appreciated.
Thanks in advanced.
EDIT: Also, WEI reports my disk data transfer rate to still be 5.9. I read that this may be because Windows is reporting my 1TB hard drive, and not my SSD. Any ideas on this?
Basing my results with http://www.ocztechnology.com/res/manuals/OCZ_Agility3_Product_sheet.pdf , I suppose there are no problems. Would switching to Marvell give a noticeable difference?
Thanks in advanced.
