Reinstalling Windows Problem
9 Dec 2006
@ManCave
So i have a HP Laptop that i want to upgrade to a SSD. Very simple & do a Clean install.
I extracted the product key using from Windows 8.1, no problem.
1. I did not want to use the HP recovery Media
(That was not provided anyway, you have to make yourself - apparently does not work with SSD's anyway?)
2. So used Upgrade Windows with A product key
(http://windows.microsoft.com/en-gb/windows-8/upgrade-product-key-only)
for Windows 8 & windows 8.1 it does not accept this as a valid license. i assume as it knows its a OEM license?
3. i have a windows 8 Pro CD, Can i use that to install normal Windows 8? with this license?
4. i do not want to buy a 256GB/512GB ssd that it wont accept due to licensing issues :confused:
So your question is, basically, can you use a W8 Pro key to activate a W8 Standard install?
Doubt it.
Just download the W8 that matches your product key
no i want to use a win8 pro cd for normal win8 key.
i have no other choice at the moment i need other options?
I CANNOT download the right one as microsoft wont let me...
You'll have to torrent it.
Windows 8.1 x86 English
File Name: Windows_8.1_EN-US_x86.ISO
Build: 6.3.9600.16384.WINBLUE_RTM.130821-1623
SHA-1: 802CFCD3A411D99C097EA7E747F0B6697F9BDAC4
MD5: 7DD36FEA0D004ACFEDBDB3A5521EF5FF
Windows 8.1 x64 English
File Name: Windows_8.1_EN-US_x64.ISO
SHA-1: BC2F7FF5C91C9F0F8676E39E703085C65072139B
MD5: F104B78019E86E74B149AE5E510F7BE9
Use one of the placeholder keys to install.
Windows 8 Core: 334NH-RXG76-64THK-C7CKG-D3VPT
Windows 8 Professional: XHQ8N-C3MCJ-RQXB6-WCHYG-C9WKB
