i wouldn't describe your average modern audi as being uncomplicated?
They aren't any more complicated than other modern cars. It's just that Audi likes to build them in strange ways and make things hard to access.
The reason is WD place a massive weighting on repair costs, so a Bentley which goes wrong once yet costs 8k to fix is somehow less reliable than a Daihatsu which may go wrong every other week yet cost 50p to fix each time.
At least 50 vehicles are neededWhat they really need to provide is how many vehicles they have on cover. They probably have 1 daihatsu and 1 bentley which makes them meaningless.
http://www.reliabilityindex.com/what-isNot all models are present on the Reliability Index - only when we have data for at least 50 vehicles will we display the results - this ensures the integrity of the Index.
This is strange...If you go to "Car Reliability Search" there no Daihatsu cars to chooseThat's okish then.
Daihatsu really sits out as an outlier then.
I think I'm wrong on the frequency comment. You guys were right, takes cost into account and length if repair which is just bizarre.
I wouldn't bet on that as a cheap Daihatsu car will most likely be far more simple then a Bentley so will have far less things to go wrong..because a raked diahatsu sure ain't gonna be as reliable as a well cared for bentley.....
Which is also part of how this survey is meaningless! Fewer things to go wrong doesn't make something more reliable. Just means there are fewer things to go wrong.I wouldn't bet on that as a cheap Daihatsu car will most likely be far more simple then a Bentley so will have far less things to go wrong..
The engine might fail more but it doesn't have power steering, air con, electric windows to have failures in. To me that's less reliable.
No. Reliability is about frequency of failures to a thing. Not multiple things.In my world if something is simpler with less to go wrong, then it is more reliable?
The thing is the car though.
Not how many things in the car.
You don't use the same logic when deciding on how reliable your TV or Washing Machine is?
Its a subjective thing, but I can also understand when people define it as anything going wrong.
