remote desktop on a LAN
1 Feb 2006
Hi,
I have 3 machines connected at home on a LAN.. is it possible for me to remote desktop from one machine to another across a LAN?
One machine is running XP Pro, the other two are on XP.
Someone once told me you must have a domain... Is this the case? And if so is it easy to set up a home network as a domain?
Cheers
just install realvnc server on the ones you want to conntact to and use vnc client to connect to them via either their ips or the computer name
VNC is probably the easiest way for a lan, however if you want access from elsewhere too try a program called LogMeIn, they have a free version which rocks!
While this isn't true, you do need XP Pro to join a domain, and you do need XP Pro to run (MS) Remote Desktop as a service. You could use the XP Home machines to connect to the XP Pro machine, but not the other way round.
Best is probably to use VNC as has been suggested.
Just use remote desktop.
You need to enable it on each PC (right click My Computer, click properties, click remote tab, tick allow users to connect remotely to my computer) also need to check the firewall to allow them access.
Then just 'run' mstsc off the run command and connect to the PC.
Much easier than using third-party solutions such as VNC.
cheers for info guys,
Will try vnc.
Will report back on how it goes
edit: just re-read this thread and realised that i should be able to RD into my XP Pro machine from my two XP ones.. THats exactly what I want to do. I have used RD in work etc so I know how to enable it etc but it still isnt allowing me.
How would I configure my firewall to allow it?
I am running Kerio Personal Firewall.
SHould I have XP firewall off?
Jonny
you CAN use VNC, I have that installed throughout my network incase I need it.
But generally I remote desktop around my machines, it's simple to set up.
If you're running Kerio then you can disable XP's firewall. You will need to configure Kerio to allow incoming connections (on the XP Pro machine) on port 3389. If you are only going to be connecting from within your LAN then you can further define to rule only allow connections from your local address range.
got this working guys using the normal windows remote desktop...
i had to disable my firewall though.
When using a router is there any need for an additional software firewall?
I am using an addon router + windows sp2 firewall and ewido antimalware.
cheers everyone who posted
