Hi guys. I've got a bit of a problem. I need to replace a motherboard in my PC. I've got a motherboard, and was going to put the old CPU, RAM, etc into it. The trouble is the CPU is stuck fast to the CPU cooler.
The problem is I can't put the CPU into the new MoBo unless I remove the cooler first.
Does anyone have any advice as to how to remove it? I've heard soaking it in Isopropyl Alcohol will dissolve the thermal paste. I've used Alcohol to remove thermal paste in the past, and it works a treat, but actually soaking the CPU will damage it won't it?
EDIT: Nevermind. My dad saw my trouble, said "I'll fix it", grabbed some pliers, gripped the CPU, and removed it. Breaking the thing in the process.
I've ordered a new CPU.
Though I'm sure other people would have had this problem in the future so if you know how to remove a stuck CPU then please still post.
