Removing a partition on a flash drive?
1 Aug 2003
I have an old 64gb usb3 flash drive which I can't seem to delete the partitions from and make one clean whole partition. Disk manager and diskpart have both failed to delete it. :( I keep getting told this,
the operation is not supported on a non-empty removable disk
I'm sure I remember some kind of 'official' program which would do this with troublesome partitions? Does anyone know what it is and where I can find it?
Any advice greatly appreciated.
I messed up one of my USB flash drives messing around with bit flipping
From memory as well as what was already mentioned think there's HP USB tool that helped lots of people
But stored somewhere on my pc is some manufacturers software that was the only thing out of an awful lot of solutions I tried that finally fixed it
Will have a look once on pc see if can find it for you if not sorted it before then
edit
software is called transcend jetflash online recovery tool
its downloadable so the online bit in names little confusing
edit
doesnt matter what make your drives are mine werent transcend ones
Thanks for the replies guys. I tried the transcend tool which didn't work unfortuantely. However a tip on the superuser forum did. It looks like running diskpart as admin is important. So too is listing the disk and the clean command. That fixed it and enabled me to format the entire drive via disk manager. :)
main thing is you got sorted
and yeah always best to run cmd as an administrator
free softwares like win aero for example can add a right click run cmd as administrator option
that way i dont forget to run it as admin lol
