OK i have a drive that is dying, its getting bad clusters all the time, so ive got a new one. The problem i have is i have 3 drives:
1 x boot drive (windows is on it)
1 x "system" drive (the one that is dying)
1 x new drive
Why has windows labelled this "system", i dont think i have anything on it that is todo with the system. I think it is because i used to use it as a paging file drive, but i turned that off (for that drive) now so is there likely to be something else?
Is there any way to get windows to tell me why it is considered "System" and then let me remove it without a problem?
1 x new drive
