Removing Antec Sonata III side panel help
Permabanned
31 Jul 2005
Hi, this is probably a stupid question but i've just got my new pc delivered and I cant get the side panel off the Sonata III case. I've read the instructions and removed the two thumb screws, it says to then unlock the latch on the panel. It looks like you need some sort of key but I didn't get anything in the box.
Is there something simple i'm missing or are you supposed to get a key in the box.
Thanks
You should have indeed got a key. Did you not get a key for the front either? Because I'm assuming they use the same key or they would have at least been on the same keyring.
The key will be inside a cardboard-box inside the case !
It won't be locked though they can be stiff when new, try and pull the case panel from the return corner with the latch raised.
Thanks, got it opened now.
Didn't realise you had to push the handle inwards to remove it. I was pushing the handle outwards and thinking it was locked. :o
Knew it would be something simple.
Yes found them, they were inside the case. :)
