- 22 Sep 2010
- Torbay
I have 2 6950s (6970 unlocks) and used a program called RacerX (can't link due to possible competitor) to remove the overclock limits in the catalyst control centre. The program edits the ATI registry settings. I was then able to set the clocks to match a full 6970 which gave me identical performance.
However when I installed the latest 11.7 and 11.8 beta the limit came back.
I used the RacerX program again but on reboot my system just hangs as soon as Windows loads up. I booted into safe mode, used Driver Sweeper and reinstalled the drivers and it's all good again.
Does anyone know any other way of removing the limits in the CCC itself. I don't really want to use Afterburner or 3rd party software as had issues with it before and using CCC is the simplest and most reliable method I have found.
Cheers
Cheers
