The easiest way would probably be to clear out the unwanted partition manually - copy anything you want to keep to the other one. Then use Partition Magic to remove the unwanted partition and extend the other one into the released space. You'll need to make sure that the remaining partition is bootable though - it needs to be set as active and have all the right bits in the MBR etc, you may need to do a fixmbr from the recovery console to set all that up.
Edit the boot.ini, remove the OS you dont want.
Boot into the OS you want to keep, delete old OS (just delete files), then you can use partitionmagic to merge partitions or format the 2nd and expanding the 1st partition
