Howdy,
Ok I assume this is the best forum to put this in, it was out of this and the Mac forum, but its more HDD related, so I went for this
My new Mac Pro come with a Western Digital WD3200AAJS 320GB HDD, and on it was the usual Journeled OS X partition, but also a 200mb GPT Protective Partition.
I'm not using the Mac Pro as a Windows machine (please don't ask why, I'm not here to get into that one
) and I am using a 250GB Seagate as the primary HDD that stores Windows. I want to use the second 320GB WD drive as a storage device for all my files, but I cannot delete this GPT partition?
None of my old Windows drives had a GPT partiton, so I assume it is not needed (and its not got any OS on it anyway) but Windows won't allow me to delete this? I tried in Disk Management in control panel, the delete options are disabled. And if I format the drive from the Vista setup, it just keeps it there?
How would I delete this? Do I need to do it via OS X? Or is there another way?
Any help will be appreciated!
ta
) and I am using a 250GB Seagate as the primary HDD that stores Windows. I want to use the second 320GB WD drive as a storage device for all my files, but I cannot delete this GPT partition?None of my old Windows drives had a GPT partiton, so I assume it is not needed (and its not got any OS on it anyway) but Windows won't allow me to delete this? I tried in Disk Management in control panel, the delete options are disabled. And if I format the drive from the Vista setup, it just keeps it there?
ta
