Removing IBM Rack Rails
7 Nov 2008
Edinburgh, Scotland
Hey,
Stupid question but how the hell do you get these bad boys out of a rack?
IBM%20xSeries%20x345%20x346%202U%20rack%20mount%20rail%20kit%2090P4011-gallery_pop.jpg
theres no screw stopping the spring loaded pins which hold it in.
For the life of me i cant make it budge 1 bit haha
Any words of wisdom? Breaking it isnt an option as they belong to a customer (gdit!)
Cheers
Push the second blue tab (the rounder one) outwards towards the side panel - IIRC - and the first tab (the taller one) then slides backward with the pin allowing you to release it from the rail holes.
Is a one hand job once you get used to it, so if it's not moving you've not moved the second blue tab far enough across.
haha that was a right hassle! Finally got it.
The middle pin sort of thing wasnt pushed in far enough. Stupid design! simple dell ones are fine.
Cheers though guys!
Cheers though guys!
I agree! Those rails have lead to plenty of scrapes and cuts! Although not as bad as the older HP rails.
