Hello all,
I've just successfully installed my first wireless network at home
however, it only properly connects if it uses Windows XP, instead of the Linksys software.
How can I remove this software or configure my PC to automatically connect using XP, instead of my having to manually switch it from the Linksys software to XP on the taskbar.
Cheers,
however, it only properly connects if it uses Windows XP, instead of the Linksys software.How can I remove this software or configure my PC to automatically connect using XP, instead of my having to manually switch it from the Linksys software to XP on the taskbar.
Cheers,
