Removing Macromedia Plugins
22 Aug 2005
Kent
Hi,
How do I remove macromedia plugins from my internet explorer? I installed the wrong macromedia authorware plugin by mistake. I looked in add/remove programs but it isnt listed.
I have winxp and using IE 6.
could try simply removing things from..
C:\program files\Internet Explorer\PLUGINS
its empty by default, and the plugin dll's will say what they are for, remove them when iexplore isn't running
