moving parts that require lubricant + wd40 = good
paint + wd40 = bad
paint + wd40 = bad
and wicksta if it's stripping wax and polish off of trim why isn't it going to do the same from paint?
Your original post came across as if you were saying WD40 would strip paint, owing to the fact you didn't mention polish or wax, but just said that WD40 + paint = bad and said it strips everything (I assumed paint came under the definition of everything).![]()
Isnt WD40 a degreaser?
i am pretty sure invented 1940 hence the name
WD40 is a water dissplacer i am pretty sure invented 1940 hence the name it also contains silicone which is not car body shop friendly wherever silicone lands you will never get paint to cover it without the fisheye effect, to remove silicone you have to clean it away with a silicone remover and sometimes it takes several goes at it to get rid of it.. The best way to remove polishes from plastic is to use petrol on a clean rag and scrub then wipe of before it evaporates you will notice the amount of black muck that stays on the rag. This is what my resprayer does, oh and also back to black is loaded with silicone, nowadays it is best to avoid car products that have silicone and it will and should say on the packaging.. AND OBVIOUSLY DONT SMOKE WHEN USING PETROL..
and what on earth are you talking about
