Removing shortcut arrows from icons
On XP using registry (remember to backup):
HKEY_CLASSES_ROOT\lnkfile
IsShortcut key, right click on it and select delete.
Reboot.
You want to be careful as some apps, if not most, that claim to remove the arrow under Vista as they will break the game folder ui.
I used this around 3 months ago to remove the shortcut arrow and haven't had any problems.
Well I can only go by my own findings, never broke my PC before or after update.
Possibly something else broke yours. ;)
No I researched it at the time and it was a well known issue. It's possible it's been rectified since either in that app or a windows update but if you're on Vista and using that app you should check if the games folder actually lets you open a game or not.
