Renaming script help needed
27 Dec 2008
Guru's of scripting I require your knowledge and help!
I will be getting a NAS on Friday and will be using SickBeard along with XBMC with it.
XBMC & SickBeard likes the TV show names in the following format (the episode name is what needs to be changed);
Firefly
Season 1
S01E01 Out of Gas
My naming format is as follows;
Firefly
Season 1
Ep01. Out of Gas
Is it possible for one of you Gurus to write a batch script that takes the Ep01. Out of Gas file name and change it to S01E01 Out of Gas.
The episode name wont need to be changed just the 'Ep01' part.
An option to manually change the season number whilst writing the new names would make it easier. I don't mind running the script in every season of all the TV shows I have.
This would be a fantastic help so I don't have to rename 60+ TV shows with countless seasons manually and thousands of mkvs :p
Thanks in advanced!
