Renaming TV Episodes
15 Feb 2008
As the title is there any software that will rename TV episodes that have being ripped from disc?
I have them set out into Folders than Episode 1 ect.
I have tried TheRenamer software but i always get !!!invalid file name!!!
TheRenamer has two modes. movies (Blue theme) & tvShows (green theme).
You toggle between the two by clicking in the centre on 'movies' or 'tvshows'. Make sure you're in 'tvshows' mode. In tvshows mode click on the bottom right to cycle to 'EPGUIDES' for database search.
I set my folders up as follows for tv;
TV > "Show Name" > Season 01 > rippedfiles.avi
After ripping just drag & drop the 'Show Name' folder into TheRemaner in tvshows mode.
It helps if the rippedfiles are named/ structured according to Season & Episode
e.g. 'House_S0101' for Season 01 Episode 01
If you need any more help ask away.
Once TheRemaner has done it's thing, I then use 'metabrowser' to gather EP data like box art actors etc.
I use MediaScout http://tvscout.codeplex.com/
Structure your series as follows
TV Show Name\Season x\Episode no
eg House\Season 1\01
You can choose how it renames files, I have it to rename to
Show Name SxxExx Episode Name
eg Lost S01E04 Walkabout
With any software, you'll at least need the season folder and episode number in some form, whether that's folder and filename or all in the name.
thanks for the reply's guys.
Think i know where i have gone wrong with TheRenamer, i have ripped the episodes like TV Show folder - Episode 1.mkv ect, i guess i need to manually rename them with the show name and series instead of just Episode ... ahwell only a couple of thousand episode to rename :rolleyes:
You could try SickBeard, I use that along with SABnzbd and CouchPotato.
SickBeard has auto rename function built into it. If you only want to use it for the renaming function, Just click "Add Existing Shows" select the location and vola.
Make sure the folder structure is as follows:
\Show Name\Season 01\blahblah E01.mkv
If the episode is a special, then it must be in "Season 00" folder.
It grabs the details from thetvdb so as long as it's on there, it'll grab the info.
EDIT: I just tried the following as you said you only named it by Episode number.
  • Renamed an episode to E01.avi
  • re-scan the folder
  • made it re-name the episodes
Sure enough it renamed it to the following:
"Showname - S05E01 - Episode 1.avi"
So it should be just what your looking for.
Hope this helps.
-Mayfair
Hope this helps.
-Mayfair
+1 - This is the setup I use and works brilliantly! I do use Media Center Master for tagging/renaming films though (prefer it to CP rename/tagging, still use CP though..)
