Renault radio codes
Man of Honour
Man of Honour
3 May 2004
Kapitalist Republik of Surrey
Stupid car blew a fuse and now the radio has forgotten its code. Anyone know what the standard code is and if there's a limit to how many times you can put one in just in case it locks the unit? Any way to reset it?
1996 Renault Scenic
different codes per set iam afraide mate there is no standard, you will have to phone up a local renault dealer probably with your chassis number or the boxes serial number.
Think it would be a Clarion then which is good as i have the code generator for those. Slide it out & write down the 8 Digit seriel code & send me it & I'll send you back the results.
Dont think it's a Clarion, they came on Peugeot's as standard.
Renault's of that age had Philips ones IIRC.
If the worst comes to the worst, take it to the Dealer and it'll be £10-£15 to get it re-coded. Remember to take the V5 and your driving licence though.
