Repackaging an OLED TV.
If you go with removals company make sure you go with one that will provide cover against damages in transit and make sure you record tv working and the whole packing process. This way they won't be able to deny liability.
They are designed to be stored upright, the packaging is weighted for this, designed to have the screen sitting vertical.
Good luck its a very scary procedure, I've done it a few times now.
I did it in the end.
I sat the TV on the floor, found some foam corner supports from my subwoofers, sat the TV on these at each corner so the stand was slightly raised off the ground, unscrewed stand, pushed it off with my foot, then I lifted TV into foam bottom container (standing behind tv) and applied all foam padding, then slipped the box on top, laid it on the floor, put the carboard bottom in, taped it up and it's not stood up for 2 weeks in box waiting to be moved.
