- 19 Dec 2006
- Saudi Arabia né Donegal
Hello all,
I'm currently trying to repair the volume controller for the Creative T7100 7.1 Surround Sound speakers having already contacted Creative Support to be told I can't get a replacement (probably should have both the Logitech system instead but can't change the past now).
Basically what's happening is that it's now impossible to set a volume, basically I have to turn it to 'loud' then fiddle with the system volume to get an acceptable level. Even then the volume doesn't stick and will get progressively lower over time or suddenly get exceptionally loud if I blow vaguely in it's direction.
I'm guessing my problem lies with a dodgy potentiometer within the volume controller but I was just wondering if anyone has encountered a similar problem with Creative speakers and had success fixing it?
Thanks in advance,
Antar.
Thanks in advance,
Antar.
