Evening chaps,
Bought my first bike a couple of weeks back, a Voodoo Marasa from Cycle Republic. Have ridden it to/from the office around 10 times so have done about 50 miles now.
Had to drop it back to the store for the third time today.
When I picked it up it had a bolt missing from handlebars and no dust caps. I noticed this at hand over so the guy in the shop took it back in to the workshop then brought it out with added bolt and dust caps. A little alarm bell did go off when this occured.
When I got it back to the car I noticed the bolt they fitted was a different size to the other 3 in the handlebars, so took it back in and got them to fit correct bolt, they couldn't find it so I suggested they remove it from the display bike and then find it in their own time, which they did.
About a week later the pedal started coming off, crank arm threads were ruined so wasn't a case of simply tightening it back up, took it back in and they re-tapped the crank arm and also adjusted the gears since dropping in to the smallest front gear would cause chain to come off (I've since educated myself on adjusting gears properly, setting L & H positions and cable tension so did tweak it to perfection myself after all of this)
Today, pedal came off again, pedal literally falls out, no threads at all to tighten it in to. Was told store manager would call me to offer a solution such as replacement parts and/or some kind of discount, which I feel is justified. I never received a call, so I called them near end of the day and didn't get an answer.
I'm really enjoying cycling and on occasion when I've had to take the car have missed going in by bike. I'm overall happy with the bike but having not owned one for 15 years and never anything other than £100 mountain bikes as a kid I've not a lot to compare it with.
My feeling is that it's a good bike but was poorly built which resulted in all of the above. The bike shop have fired the guy who built my bike as have had other issues with other customers. The staff I've dealt with have been friendly and seem knowledgable and interested in cycling.
I'd appreciate your opinion on if I should just push for a full refund and purchase a different bike from elsewhere (will have to be different since only Cycle Republic/Halfords stock this bike), like an independent bike shop (loads of bike shops in Bristol so will find out which are best) or give these guys another chance to put it all right.
The bike was £400 with a 10% off promo day so £360, I'm not wanting to spend any more than this at present.
