replace a x1950 pro = same watts or less
7 Dec 2002
South Wales
Anyone have any recommendations as to what single gpu card i can replace my 1950pro with that will have the same or less max power drawn and still have a significant boost in performance!
Lookin for sub £100
not 100% sure but the 4770s maybe a good place to start
they dont need a pcie power connector for a start
The 4770 which is currently out of stock...the other option is the 4850 but I think that needs slighly more power...also i don't know how the gts250 fares...
Or i could tell you i have a OcUK Huntkey 450W Power Supply
Running a
E6420 using 1.4v
2Gig DDR800
1 HD
1 Optical drive
1 Card reader
Antec900
4850 should run fine on that pc, unless you have actually tested cards with a higher power draw and it results in stability problems
well your CPU clock speed may play a part in what you should get, as well as your res
personally i would get the cheapest 4850 and some more ram giving myself a minimum of 4GB
