Well in that case it must be either the Asus Xonar DG or if you do have PCI-E spare the DGX. Both have nice opamps and will drive those badboys fine![]()
Of equivalent value yeah it pretty much does
I just replaced my Xonar Essense STX with a Beresford Bushmaster DAC and just using the motherboards SPDIF sounds absolutely amazing by comparison, the bass is so much deeper and lovely clarity.
I'm using HD595's.
I'm using HD595's.
Negative.
DACs can be better than each other but in all honesty it's not what changes the sound massively.
The amplification arrangement will do far more for the sound than the DAC ever will.
The STX, for example, drives high impedance cans perfectly and has no interference issues at all. At least not in my system.
You get the benefits of Dolby positional stuff should you like to use that in games. Yes, you can get it in external solutions, but hello ££££.
I'd bet money that you couldn't tell the difference in an ABX test with levels matched. Not doubting you hear a difference but it's placebo if you haven't changed something else in the process.
Not really. I bet he could tell a difference in clarity alone
