Hi
My 5 year old Bebox recently failed and I was sent a Technicolor replacement. The problems listed below meant that I was sent a replacement Technicolor within a week. The replacement has the same problems. It is driving me crazy. 5 years of problem free service have now been followed by:
- wired connections not being able to connect to the internet (while wireless devices work). They are connected tot he network though. If i go into ipconfig they can see the modem and have an IP.
- some appliances having wirless internet access whilst others do not (they are conencted to wifi).
- a power off/on not resolving the issues, only logging into modem and restarting through software works. this means running around house trying to find a device that can connect to modem (whether wired or not).
FYI my set up is an ethernet going through a switch to the modem.
What the *Fully star out swear words* is going wrong?
Be support have not been able to help.
Are there any cheap (under £40) replacement boxes I could buy. I dont want to buy a £100 replacement.
		 We've all been there with dumb mistakes, I guess
