Right i've decided i want a new fan/cooler for my x850xt as the noise from the stock one is driving me nuts. I've played around with different settings for it on Ati Tray and cant come up with anything that doesnt annoy me enough to stop using headphones and start using my speakers again while gaming whilst at the same time keeping the card cool.
I've had a look at the ones on OCuK but they all say silent or quiet yet i know some will be louder than others or better so i'm slightly confused as to which one to get
Can anyone suggest a quiet efficient replacement cooler for this card for the sake of my sanity
I'm not wanting watercooling as i just dont trust water around the pc. Any suggestions made could you also let me know how easily it would be to fit.
Cheers,
Zeph.
I'm not wanting watercooling as i just dont trust water around the pc. Any suggestions made could you also let me know how easily it would be to fit.Cheers,
Zeph.
Even when not playing games it is significantly loud. At one point i took it out and ran the monitor through the on board graphics just to test and the PC was almost silent and thats including the Opteron heatsink which i am pretty pleased with for noise and cooling considering its the one that came with the CPU.
